Old Apr 21, 2009 | 07:22 AM
amx1397
Default Re: Help With Wheels
our crossfire came with an offset od 22 rear( with no lip) and 30 on the front (no lip) if your wheel has a 35 to 45 with a 2 to 2.5 lip it will equal the same in other words look at the stock wheel it is flat across the front top to bottom that is no lip. hope this helped. I have lug bolts if you need then (you can't use stock bolts unless the hub is the same thickness , jim
https://www.crossfireforum.org/forum...ad.php?t=33173
