Originally Posted by liljay
How many miles on the car and have you changed the spark plugs? They are good for 100k miles. Start there. It is the cheapest. A set of good ones should be around $130. Read your codes and you should get one related to the crank position sensor or some postion sensor. I'm at work and can not look the code up.
Ahhhhhh, he said he wasn't gettin a CEL ! (Check Engine Light) Therefore no codes ! The crankshaft sensor is also a possibility which when you do a search will find the thread "Mystery No Start" the CPS is covered along with the RCM !
