Old Apr 21, 2009 | 03:09 PM
blackcrossfire07's Avatar
blackcrossfire07
Default Re: Solution to window water leak...
They better have fixed mine. It looks like they could have done a better job adjusting the window. But I am going to see if it works. If not, it is going back.
I wouldn't do the pipe thing. The problem is the window needs to fit tightly under the top rubber. No water should be getting through the window in that rubber tunnel at all (unless you open the door and a couple drops drip in). They probably put the pipe in the audi because it has auto locking windows and the pipe helps slide the window up in the right place. Our problem is the opposite.
