Old Apr 21, 2009 | 09:46 PM
  #296 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: V8 Crossfire Conversion Diary
Karim,
Great progress and glad to see pictures. I was wondering where you had gone but figured you were waiting on parts. Are your exhaust manifold going to work? For the Crossfire we need to use the C43 type. the Crossfire also has a different crossmember under the engine and I am still not sure if the rear sump pan or the CL pan will work. The Crossfire's V6 uses the front sump and after lots of measurements it looks like the CL pan will work. I had also detimined that the V6 engine mounts will work but not the CL engine mounts. I am anxious to learn more about the ECU once you get that done and working. Keep up the good work!
