1.
Turn the ignition off.
Disconnect all jumper wires and reconnect all previously disconnected components and connectors.
Note: If the SKREEM or the PCM was replaced, refer to the service information for proper programming
procedures.
If the Body Control Module was replaced, turn the ignition on for 15 seconds (to allow the new BCM to learn VIN)
or engine may not start.
Program all RKE transmitters and other options as necessary.
With the DRB III
T, erase all Diagnostic Trouble Codes (DTCs) from ALL modules. Start the engine and allow it to
run for 2 minutes. Operate all functions of the system that caused the original complaint.
Ensure that all accessories are turned off and the battery is fully charged.
Turn the ignition off and wait 5 seconds. Turn the ignition on and using the DRB IIIT, read DTCs from ALL modules.
Are any DTCs present or is the original complaint still present?
Are any DTCs present?
YES
>> Repair is not complete, refer to appropriate symptom.
NO >> Repair is complete.
It actually states the BCM should self learn, But the key fobs need to be reprogramed. At least that is my take on it
