Thread: Mopar Cat Back
Old Nov 23, 2004 | 12:46 PM
mbepic's Avatar
mbepic
Exclamation Re: Mopar Cat Back
Originally Posted by ZLMan440
I found this on another forum and wanted to know if anyone had seen it before. Mopar is asking $576.40 for it online plus shipping. Its at http://www.mopersupercenter.com its said to give 8-15 hp on the other forum (who knows if thats right). This is whats said on the site: Mopar Performance Cat-Back Exhaust Systems, including the muffler, feature T304 stainless steel construction (aircraft quality) with mandrel-bent tubing, stainless band (torca) clamps and polished tips.
These free-flow systems provide a horsepower and torque gain, improved fuel economy and a deeper tone.
I may be wrong on this but this looks like a two piece exhaust system with full duals from the muffler back. My guess is the the replacement muffler fits onto factory twin pipes about mid-section of car and from there the two other pipes with "tips" run to back of car.
if the muffler pipes are "straight through" with some muffling material surrounding, you have a full dual system that would probably work quite well. What I can't figure out from the pic is whether the tail pipes are routed parallel to each other on drivers side of differential or spread out enough to be routed either side of diff. Running pipe on passenger side of differential is a little iffy because of the gas tank/fuel pump, etc.
