Originally Posted by Skyshadow
This is a good reason to
read the factory owner and installation manual before purchase.
You might have dodged the bullet though. Check section 5 of the owners manual:
Using the AUX source
Up to two auxiliary devices such as VCR or portable devices (sold separately) can be connected to this unit. When connected, auxiliary devices are automatically read as AUX sources and assigned to AUX1 or AUX2. The relationship between AUX1 and AUX2 sources is explained below.
About AUX1 and AUX2
There are two methods to connect auxiliary devices to this unit.
AUX1 source:
When
connecting auxiliary equipment using a stereo mini plug cable Insert the stereo mini plug into the input jack on this unit.
For more details, refer to the installation manual. (Click)
This auxiliary device is automatically set to AUX1.
AUX2 source:
When connecting auxiliary equipment using an IP-BUS-RCA Interconnector (sold separately) - Use an IP-BUS-RCA Interconnector such as the CD-RB20/CD-RB10 sold separately) to connect this unit to auxiliary equipment featuring RCA output.
For more details, refer to the IP-BUS-RCA Interconnector owner’s manual.
This auxiliary device is automatically set to AUX2. You can only make this type of connection if the auxiliary device has RCA outputs.
Selecting AUX as the source
Press SRC to select AUX as the source.
If the auxiliary setting is not turned on, AUX cannot be selected. For more details, see Switching the auxiliary setting on page 30.
Setting the AUX title
The title displayed for the AUX1 or AUX2 source can be changed.
1 After you have selected AUX as the source, use MULTI-CONTROL and select FUNCTION to display TitleInput "A".
2 Enter a title in the same way as the built-in CD player.
For details concerning operation, refer to Entering disc titles on page 18.
Using the external unit
External unit refers to a Pioneer product (such as ones available in the future) that, although incompatible as a source, enables control of basic functions with this unit. Two external units can be controlled with this unit. When two external units are connected, the external unit is automatically allocated to external unit
1 or external unit 2 by this unit.
Basic operations of the external unit are explained below. Allocated functions are different depending on the connected external unit. For details concerning functions, refer to external unit’s owner’s manual.
Selecting the external unit as the source
Press SRC to select EXTERNAL as the source.
