Originally Posted by hawksview
i think euro said they had the pumps in stock mat
Didn't see this post until just now, but I did end up going to Eurocharged today. Jake was in and getting some work done on an E55. Thanks to Jerry for letting me know Jake was in the shop and thanks a ton to Jake for switching out the pump quickly. Well done.
On a side note: I'm still have the SC disengage...not sure now what it is. I may have to take it back to Eurocharged and get it hooked up to the comp...
Jake: Any ideas on what it may be would be greatly appreciated...and can you let me know when Jerry is getting back and could hook up the diag on the car...I can do after 5 any day this week or anytime Saturday...
EDIT: Could it be the intake temp sensor? Because other than that it may be a bad SC clutch in which case I am F'ed....then again, hopefully the comp reset will fix it.
I disconnected the battery tonight and am hoping resetting the ECU will fix the problem...
Philly, I'll post up what ended up being the fix for the problem...as I think you are seeing the same thing. Hopefully yours is just the pump.
