Thread: IC Pump Failure
Old Apr 26, 2009 | 08:54 PM
oledoc2u
Default Re: IC Pump Failure
I have a pump on the shelf, but it turned out to be the sensor, fixed under warranty, but it took the dealer 3 days to figure it out...go figure...good luck to you both...RokyPoky...the sensor didn't throw a code or turn a lt on so to speak, because it was intermitant...work for awhile, not work for a while...copy this post and take it with you...my dealer tried everything...and this was before I found this forum...everything they need to know is here on the forum...it will save you a lot time and arguing...good luck to you too
