Old Nov 24, 2004 | 03:53 PM
rick333's Avatar
rick333
Default Re: Brake Pad Replacement FAQ - porterfield
I just noted the brake pad replacement that was posted 5-30-04.
One thing was missing that should be addressed which is when pushing back the pads for removal, you should crack the bleeder valve so that the contaminates in the fluid won't be pushed back in the ABS which, as you can imagine, is very expensive. Top up the brake reservior with Dot 4 as recomended by the Manufacture when finished.
Rick 333
