Originally Posted by apkano
We are both right. I was referring to the bellhousing and you are referring to the flywheel. If there is a difference in the flywheel pattern, I would try to get the flex plate from the s/c donor engine and then find a flywheel that will bolt up and take the new flywheel and old flex plate to a machine shop that builds engine and make sure the new flywheel has the same balance factor and the flexplate.
