Old Apr 28, 2009 | 08:58 PM
  #138 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: Squires rear turbo system.
Originally Posted by faiz23
i do not like the idea of the turbo under the car in the rear for safety reasons what happens if i bottom out and hit a hole or something where the turbo will be located i am worried. what about relocating the battery to the rear and putting a turbo in that area or relocating the overflow tank and putting a turbo in that area. if we can just get a custom piggy back then i do not see the issue with just fabricating some piping and fitting a turbo. what is the highest pounds of boost we can run using the piggy back. i figure stock engine should do 8lbs-12lbs of boost and more if you get the forged internals.
I kind of like the idea of putting the turbo in the rear. Since you really don't need a muffler you could put right behind the rear end center section at the very begining of the muffler tunnell and then run pipes and tips out the normal exit. since I don't hit my muffler, I don't think a turbo is in any danger.
