Thread: Coolant
Old Apr 29, 2009 | 11:01 AM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: Coolant
Originally Posted by Goldwing
Dumb question - where are you getting the temperature read out? My guage just shows H-M-L. All three pretty much run at the M or a needle width either side (lower in cold weather, a tad higher in hot weather and traffic). I've been in bumper2bumper traffic on a 90o day and the roadster only went a needle over the M.
Datalogger, they are able to display multiple operations simultaneously for scrutiny. One of the operations I view consistently is coolant temps. If looking at your OEM coolant needle and its touching the bottom side of the halfway line, your coolant is around 190 degrees. If the needle is centered on the halfway line then the coolant temp is about 196. If the needle is touching the topside or over the halfway line, expect your temps to be 198-201.
