Old Apr 29, 2009 | 07:21 PM
Glockhit's Avatar
Glockhit
Default Re: Will this MB Wheel / Tire combo work as a spare?
Currently attempting to get my head around which MB wheel /tire combo will work as an effective spare.
MB ML350 17" wheel
Tire is ML320
Width is 7.5J / 235
Bolt pattern is 5 x 112 mm
*Will an 18 inch wheel with similar characteristics also work?
Can I toss this one in the trunk, then call it a day?
Thanks for all of your help and comments!
Monty
I hope this helps. If you can actually get/twist your head around the MB wheel and tire it's going to work. Use this as a guide. It takes a pretty good stretching of the neck to do this. Good luck. Let me know if this works.
