Re: Body Control Module Problem
Just confirmed the following:
On the 2007 XFire you can not program the Body Control module with the DRB III. The DRB III will work on the 2005/6. On the 2007 you must use the STARSCAN with a CH9427 green cable through the port on the driver's side. I am not sure if this is the case with the 2008. So I guess NOT all XFires are created equal.
The WITECH system does not have a program for the Crossfire.
