Old Nov 28, 2004 | 09:08 AM
mbepic's Avatar
mbepic
Question Re: Tire (Air) Pressure Problem - Please help
Originally Posted by sambo13
I've had the same problem with the tire pressure sensor. Had to bring it to the dealer 4 times. They tell me that temperature changes are causing the light to go on. Here's the rub, the dealer is trying to charge $22.50 each time they reset the sensor. Not only do I loose 4 hours from work, now they are charging for something I have no control over? Like I said in prior posts, these crazy problems make the owning of my Xfire a pain in the as*. I love the car, hate the Chrysler service and mentality.
Not sure what the dealer is trying to do to you here.
They tell you that it is the colder temp that is setting off the sensor (that may be true as I experienced that first thing in morning earlier this fall) and then they say they have to reset the sensor each time at cost. If what they say is true, why don't they or you just add a little more air to the tires and that should resolve problem.
If it is not true and you have a defective sensor or defective something else, why are they charging you anything. The warranty should take care of defective whatever.
Your right about the service and mentality of the dealer. If it's true what they are doing to you, they are simply taking you to the cleaners. I can't understand why they had to take you to the cleaners four times.
