Re: Grinding at Redlights ABS BAS ESP Module
my car has had the CAB replaced, the steering angle sensor replaced, the yaw rate sensor replaced.
Now they are digging around in the wiring and feel as if they are back at square one.
the techs are scratching their heads, and claim someone has messed with the wiring in the past based on the condition of it.
if the highbeams are on and i beep the horn, it makes the ABS light flash.
the foglights cause the speedo jumping around issue and cruise control to cutoff
BAS ESP light will be off at start but comes on as soon as you move the steering wheel
radio gets quieter when highbeams or foglights are turned on
will it help to call the dealer i bought the car from? i bought it certified pre-owned 8 year 80,000 miles.
i can't believe this is happening when all the bankruptcy issues are happening.
