Old May 6, 2009 | 12:06 AM
faiz23's Avatar
faiz23
Default Re: Removing Rear Bar!!!
depends where you are mounting it to but you gotta be careful and if i were you do not drill into the car instead slide a piece of plywood or MDF and then screw the amp to the wood.
if you are talking about the hump in the rear what i would do i remove the carpet and expose the metal and pull that metal cage off and mount a piece of wood and then screw the amp to the wood and install the metal cage back on.
