Old May 6, 2009 | 09:02 PM
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: Christmas in May! (courtesy of Needswings)
Originally Posted by waldig
I designed the dual with 3" hose fitinto the space on the driver side, Rob revised it to be 2 3/4" and it fits better.
On the same dyno I ran the dual with a baggy over the second filter and then tested it with the pair of filters running in parallel. I got 1 PSIG more boost, and 35 hp on the bottom end, below 2500 rpm. at the top I got 7 hp overall but the bottom end really carries the car faster off the line and it makes a big difference. The restriction in a single filter and 3" pipe was 30" of water at WOT or the 1 psig.
W00DY
I've been trying to tell forum members the advantages of a 3" dual intake for some time. Glad you discovered it.
Now, just imagine if you had two huge, less restrictive air-filters and took advantage of ram-air the intake openings provide and your tubes weren't so darn hot.
If you enjoy the added HP at the bottom end now, wait tell you get that 185mm installed.... you'll get 10-15 more HP at the bottom and 20-25 more at the top.
Then a tune.
Enjoy....
