Old May 7, 2009 | 08:10 AM
  #81 (permalink)
psuperti's Avatar
psuperti
Default Re: 74mm Throttle Body Upgrade
Originally Posted by Stogey
Got the 74mm TVT TB and NeedsWings CAI installed last night. Didn't have much a chance to test it out until this mornings commute into the city. I must say that I was a lil disappointed at first but then I thought well I need to pull in and grab some go juice and did a throttle reset while settin filling the tank. WOW ! Midrange from about 3200 rpm on up to around 5000 is simply beasty as compared to before. Wondering now if the larger TVT injectors will help out the low end
The different sound you hear is your new intake. When you buy the injectors buy them bigger then 19lbs per hr. 19 was to small for me!
Problem! throttle reset is not coming (as a thread tittle) up on the search! I don't have the time to read every thing in there. Can some one post the instructions here? You know as part of the instal steps
