Old May 7, 2009 | 03:02 PM
  #38 (permalink)
faiz23's Avatar
faiz23
Default Re: '08 limited coupe system complete WOW!!!
also if you are wanting to do it right please spend some good money to get some 1/0 gauge wire so you never have to worry about resistance in the wire. i ran a 1.0 for power and ground and than ground in the rear as a backup as well.
i upgraded the grounds on the big three waiting on some more wire to do the alt-pos wire.
get a mini battery in the back instead of a cap you will spend 100 bucks to get a 1-5 farad cap. my little kinetik battery is around 125 shipped and will be equilvilent to 200 1 farad caps.
also you need to get a bigger battery deep cycle to sustain heavy bass drops.
kinetik says i think you need like khc 1400 as starting battery and then anything on top will be your system.
i have a khc 1800 and a khc 800 for a total of 2600 watts- 1400 for starting = 1200 watts which is fine since you will never max out your system and use all the wattage unless you are doing heavy competition bass burps.
enjoy
