Old May 8, 2009 | 03:07 PM
  #91 (permalink)
MisterTaz's Avatar
MisterTaz
Default Re: 74mm Throttle Body Upgrade
I believe that the opening is around 68 MM stock but can be machined to 74 MM. When I went to order my TB TVT had already run out of available units for sale (That's what I get for not pulling the trigger when I first thought about it). However I went a different direction and got one that has been machined to 74MM by AMS from over on MBW.
I worked with Omey (AMS Owner) to get mine but I think even his supply has dried up as well; hence Anthony's "Most Wanted" statement. The AMS route was a bit more expensive than TVT but I did not want to go without (I'm selfish that way) . If you would like I can take a look and give you the casting number on my AMS unit if you think that will help...
I can tell you that I am still holding onto my stock TB waiting for some other "Goodies" so I know of at least one stock TB that will be available to be modified from AMS soon.
Stay Safe...
Respectfully,
Paul (MisterTaz)
