Re: Do it yerself DIY Belt Wrap Kit for less than $25
wow that is simple as can be, good stuff man.
what length bolt did you use, in your writeup you just say it is MM long.
I found several "ebay" pulleys that are smooth not grooved that may work.
Thanks for the info though, I am going to do mine!
What is the size of the idler pulley you used? If you have that then it shouldn't be too difficult to find a smooth pulley somewhere.
also, can you circle the pulley you removed then circle the pulle/bracket you replaced it with so it is clearer what you moved/replaced?
