Old May 9, 2009 | 05:31 PM
onehundred80
Default Re: Trouble Starting... Exhaust leak...
I would connect the loose hose, reset the codes and drive the car again and see if the same codes come up again. This would then not have the code set for the loose hose, I am assuming it set a code of course.
I assume that the code; P0171 - System Too Lean Bank 1 was set by the loose hose.
