Old May 10, 2009 | 04:05 PM
drivethruecp's Avatar
drivethruecp
Default Re: Trailer Hitch Installed
Originally Posted by BLACKSRT-6
I figured the racing group would be the most interested in how this turned out. It's unpainted until the rain stops but that actually makes it easier for you to see.
Looks great. I've been following this for quite some time. My intrest is to do the two receiver boxes but also modify a dirtbike hitch holder. The ones that hold the bike perpendicular with the trunk. The two hitches would give it better stability from tipping from the standard straight single hitch.
So I am going to cut off the single hitch from the center of the dirtbike rack and put two on either side to line up with the two receivers. Can't we use two universal boxes that just have re mounting plate welded on top rather than the traditional tubular brace that's car-specific? Would you mind taking a few angles of pictures of your receivers mounted to the frame underside of the car? It would be much appreciated!!
