Re: MAF sensor
You remove the MAF sensor by removing the two security torx screws (as you mentioned), then pulling it out - BE CAREFUL. It is located just below the rear of the airbox cover - remove that and you would be able to see it - there will be some wires running to it. I can't tell you any more than that as I have the Needswings intake and the MAF is in a little bit different location.
