Originally Posted by PhillySRT
Sorry to hear of your continued issues. If you have intermittent SC problems and it isn't the sensor or the IC Pump, could it be the SC clutch itself that's malfunctioning?
I've thought about that...but there is no slippage of the SC clutch, which I personally think I would feel especially under load. I am going to check wiring connections tonight. If there is an intermittent short/bad connection then there would be no codes stored because it fixes itself when the connection becomes good again...but I don't know if it is a short because it very evidently a temp issue as the problem only occurs once the engine warms up...and gets to 'running' temps although those temps are quite high (192F under full load w/ SC engaged and 172F during normal running w/ SC engaged or disengaged)
I think I just talked myself in a circle back to square one...I am still going to check the wiring tonight for solid connections incase the IAT sensor is intermittently shorting out... who knows.
All I know is I want my car 100% by track day damnit.
