Old May 13, 2009 | 10:38 AM
  #43 (permalink)
distantpulse's Avatar
distantpulse
Default Re: Extreme Makeover: Engine Edition
Originally Posted by cross><hair
Do a burnout for a few seconds until you see smoke, roll out of the burnout, stage as shallow as possible, load the engine (power brake) to about 1500 rpms, then swap feet (foot off brake as foot slams on gas) and GOOOO!
With that technique I don't feel much wheel spin at all (if any) thus the reason I'm skeptical about investing in slicks.
I think he has a good teacher, but what do I know. :P Seriously though, what Glen said is right, but I would like to add a little more detail.......When you do the burnout, don't sit in the water and burnout. Pull up so your back tires are just out of the water (If you have a good track employee, he will help you). As you do your burnout, look in your SIDE view for smoke and once you see smoke, hold it for an extra 1-2 seconds and drive out of the burnout! Don't let off the gas when you are coming out of the burnout. You need to actually give it a little more gas while you drive out of it because the tires will want to grab. I found the sweet spot staging the car from 1600-1800 RPM or right on the verge of the coverter wanting to lock up.
I will also note that the track prep is VITAL for you to acheive 1.7 60's. Atco is great and Glen and I are lucky to have this track near us. We <3 Atco!
