Thread: best pulley?
Old May 14, 2009 | 02:51 AM
Eric's Avatar
Eric
Default Re: best pulley?
Originally Posted by cruzinquick
Didn't even know SRTPowa sold his car. Can you tell us what mods were left on the car that may make it easier to make a recommendation. I think he had a 178mm ASP crank pulley on there first. Can't remember.
heres the list
Stock pulleys
BDJRacing Intake Manifolds
Needswings intake manifold gaskets
Needswings Catch Can
3" Intake = SRTPowa made it himself
AEM Dryflo filter
NGK Iridium plugs one step colder, gapped to .30
TSW Snetteron Wheels 18x8(35mm ET) 19x9.5(22mm ET)
Nitto NT05 Tires with less than 1000 miles 235/40/18 275/30/19
Eibach springs
Johnson CM30 pump
1 Gallon Intercooler tank
LET heat exchanger
Deka mini battery(AKA Braille)
PLX Devices Wide Band with LCD display
runs at about 15AFR acording to the wide band when just cruising
I beleave your right with the 178mm ASP,, it was the code3 beltrap kit he had also i was thinking of
