Originally Posted by brhertel
I have read all the literature, searched all the issues, and I HAVE A STUMPER:
My engine cranks just fine, no start
Replaced fuel pump
Replaced Crankshaft Position Sensor
Replaced Relay Control Module
NO Check Engine Light
Will crank for days but will not catch. 62,000 miles
What made you change out three components so quickly?
Was this a problem that started suddenly or did it slowly get harder to start?
I always start on the simple things to check and then go to the more difficult items.
You are not at the point of running out of gas I assume when the pump is sucking air as well as gas. Spark plugs that are wet with gas normally rules out fuel problems. Can you hear the new fuel pump? Is a spark present?
Using a multimeter that can measure low ohms values is vital to checking all the sensors and is well worth the investment.
