Thread: Black dust :(
Old May 15, 2009 | 10:13 AM
onehundred80
Default Re: Black dust:(
Originally Posted by aussiedude
just changed my belt, and now have black dust in the engine compartment
is this ALWAYS an indicator of belt slip, or might there be some kind of wear in on the new belt?
Are you sure you have the belt correctly lined up in the grooves in all of the pulleys? The belt could be offset and rubbing against something or the offset will flex the belt side to side and cause rapid wear.
Is the tensioner giving the correct tension, if the new belt is too long it will slip without the correct tension.
