Re: Pressure in tires OK, low pressure Icon on.
All good points, but did you check your tire pressure when the tires were hot? The sensor will alert you if the tires are off by 10%. So if you checked them when the tires were hot, that might be your difference. Make sure you check then when they are cold.
