Old May 17, 2009 | 05:33 PM
nox1s's Avatar
nox1s
Default Re: Healight Projector Broken?
Originally Posted by rakoom2002
I am trying to re-aim my passenger side projector, however it only points at the ground, for instance, I can push down on the back part of the bulb and it will face upward (the projector) but once I let go it falls down again. I have tried adjusting with the adjustment **** but it doesn't raise the projector it will only lower... do you think this could be due to the bulb not being seated correctly?
Yes.. it probably is not seated right.. this is the problem with 99% of headlight bulb installations on this car..
Check your H7 bulb, it should have a flat notch.. this is the bottom of the bulb. There's a place in the headlight housing for this notch to "slide in".. hard to describe.. check out the HID installation guides, the'll help.
