Lower tire pressure will tend to wear the edges faster. Higher pressures will cause wear in the middle of the tire. I will continue with what the door jam tag has printed. 32/33
James
I'm with you James, I keep my tires at the recommended pressures. Having said that every time I take the car to the Dealers for service, I get it back with 36 psi on all 4 corners.
