Originally Posted by Crossfire725
what is the easiest way to remove both fog light lamps completely
thank you for you time
Fog lamps may be accessed via the small plastic door in the forward surface of the wheel well splash shields. I believe you'll need an 8mm socket to remove the 3 nuts holding each one on. Easier if you remove the wheel first. Good luck! Oh and be sure when you close the access door it is secure otherwise you'll be replacing it after it has rubbed away against the tire surface......believe me I know!
