Re: 350 hp no problem!
The issue is not boost pressure, but tuning. Unless you are going to run separate stand alone electronics for fuel and spark, forget about it until someone comes out with a tuner that allows control of these elements in the DC ECU. Under virtually any boost you will break stuff if you get pre-ignition. This is virtually always the problem with parts failure.
If someone can get me into the ECU, I will do a supercharger project.....but not before I can make the car run right afterwords.
