Originally Posted by Tazz
Yes, used 5mm on the front to clear the calipers. Sorry, I just cannot bring myself to grind down the outside of the calipers and then trust my a*s to them at the end of the straight at 220kph!!
I sure wouldn't grind on the calipers either. I am more curious about what wheel fit the set up. I have the S/CL class version which uses the 330mm SRT/SLK32 rotor and they did clear my wheels. If I Had gone with the C32 345mm rotor, I would even have more clearance. Just remember that as long as your front bearings are good you only need enough clearance to slide a business card into.
