Old May 25, 2009 | 12:01 AM
bhays's Avatar
bhays
Default If you are installing eibachs on your srt...
If you are installing eibachs on your SRT and it's the first time you have done such a job, a few notes..
1. Don't be alarmed that the Eibach springs are longer than the factory springs, they will sit lower.
2. Be sure to rotate the rear springs so that the end of the spring sits down into the little pocket in the lower A-Arm before you reassemble... (ask me how I know).
For a few minutes this afternoon I had the first off-road SRT6... oh well, if a job is worth doing it's worth doing twice
Also, don't assume that your rims from your base roadster will fit your SRT... calipers hit in the front due to being much larger than the base calipers... already ordered 5mm spacers and longer lug bolts from ezaccessory.com... Ticks me off as I ordered 15mm spacers and lugs for the rear and didn't even consider the fronts since they fit fine on the other Crossfire...
