Old May 25, 2009 | 08:38 AM
  #84 (permalink)
Scottyw1's Avatar
Scottyw1
Default Re: Nitrious Oxide!! Please Advise.
Originally Posted by kolevski
Okay I realised what I did wrong! I dont know where to put the jets!! I've got the correct jets I looked in the book but I'm not sure where to put them I'm assuming in the "OUT" section of the nitrous and fuel solenoid?
If you are hearing gas hissing from the system, the jets won't fix that, the jets come into play after and only when the soleniod is open. A gas hiss(escaping gas) indicates a possible incorrect connection, missing gasket/o-ring or small hole in a line. Check and double check all connections.
The small brass jet goes inside the nitrous nozzel to restrict the amount of nitrous flow, it is probably a blue anodized nozzel that is plugged into the system right before your MAF.
The fuel side is probably red anodized fittings.
What kit do you have?
DO NOT attempt to use the system without the jets!!
