A good indicator of alignment is if the HIGH beam is also pointing too far down. I use a tape measure from the ground and use the cut-off line to compare the relative heights from the ground ~ 2 feet in front of the beam.
If BOTH the HIGH and LOW beams on the passenger side are pointing down, the adjuster screw is backed too far out. (Or both bulbs are installed incorrectly). As for getting it re-threaded, I don't know. I've never gone that far, sorry.
i never tried the high beam on also but id guess it would be the same the bothe projects move at the same time.....but if i pulled up to a driveway door...both headlight should line up about 2.5 feet up? is that what you mean?.....but would the headlights not adjust is the bulb wasnt seated correctly? is there away to tighen the projectors lenses....cause they may be loose?
