Old May 25, 2009 | 10:44 PM
Crossfire725's Avatar
Crossfire725
Default Re: Healight Projector Broken?
Originally Posted by Crossfire725
i never tried the high beam on also but id guess it would be the same the bothe projects move at the same time.....but if i pulled up to a driveway door...both headlight should line up about 2.5 feet up? is that what you mean?.....but would the headlights not adjust is the bulb wasnt seated correctly? is there away to tighen the projectors lenses....cause they may be loose?
i cant figure it out. i tried to messaround with it for a bit...what can it be?
