Originally Posted by kussh
just wanted to know how do u reset the throttle what steps do u do to reset it?thanks
It's fairly easy.
1. Key turned to the ON (does not have to be running)
2. Press the pedal to the floor and hold for couple of seconds.
3. Turn the key off - LEAVE THE KEY in the switch....let set for 2 mins ( oh yeah you can let up on the gas now)...
NOTE: Important to allow the key to remain in the switch for 2 mins. The throttle "memory" will be purged and the car will "relearn" how you drive. You should notice some improvement in throttle response. Don't expect "burn out" response..but you should see some difference.
