Old May 26, 2009 | 07:54 AM
240M3SRT's Avatar
240M3SRT
Default Re: Code3 Memorial Day sale!!
Originally Posted by velociabstract
I don't blame you for feeling the way you do towards Code 3. My aluminum pulley arrived and had issues with the clearance not being equal all the way around to the clutch. But I also read if it wasn't too far off it would wear in so to speak. I need to take measurements now that its been on for a while and see if it has. But it's not slipping, rattling and it's boosting as expected. After changing it once it really is a 15 minute job swapping back to stock. My stock pulley had 45 mm of clearance to the clutch and the Code 3 has a bit more. The instructions say it should be around 20 mm. I don't know where that number came from. Also the tensioner is not a T11. Its a T10. So ignore the instructions. And for Pete's sake, get the proper tool to hold the pulley to get the bolt loose. I have a feeling that some have cranked so hard on the snout of the supercharger following the removal instructions that they've damaged it. The pulley works, the quality control is suspect and the instructions are dangerous. IMO. (bonafide Code 3 first hand owner and user)
Les
Les, have you contacted Brandon directly about your issue?
BTW it looks like the sale has been extended until the end of May (i believe thats Sun the 31st).
