Thread: General Info
Old May 26, 2009 | 09:10 AM
Rapps's Avatar
Rapps
Default Re: General Info
Originally Posted by Bigkid
Oil change is expensive but the suggested interval is 7k so it is not as bad as it appears. Check the interior door pulls for separation at the seams in the metal against the door. Sometimes these get sharp and can cut a finger when closing the door. If the car has this problem get them to fix it b4 you buy. Good luck , you will both enjoy the car.
The replacement part is $70ish each. We have had several sliced fingers and so took a very soft old finger nail file (paper kind with the foam in the center) it did the trick at least for now.
Check the radio, does the screen/lettering "run" when cold? Expensive to buy a new one unless under warranty.
Post the details; price, miles number of owners. Many members here can give more advice with that.
