Originally Posted by kolevski
Thanks Scott,
I fixed the problem with some thread sealer! now my other problem is I set it up for 50hp and when I use it I cant feel to much of a difference could this be due to where I placed the jets?
I put the Nitrous jet on the actual piece that is attached to my TB and the fuel jet in the "out" hole of the fuel solenoid... hrmm
If you can feel the nitrous kick in, but it seems more like a 25-30 shot it is
probably bottle pressure, internal pressure should be about 950psi, cool temps can greatly affect the system preformance, which is why a bottle warmer is useful.
if you have a pressure gauge on the bottle check that, if its below say 800psi you are not getting near a 50 shot. I am working from memory on the pressures, but somewhere in the manual you should find info on system pressures, min and max.
Long ago on my first nitrous powered mostly street car, I had the same problem, juice kicked in but just did not seem like a 75 shot, checked my pressure it was like 750psi; installed bottle warmer problem solved
