Old Dec 11, 2004 | 10:43 AM
Dan Root's Avatar
Dan Root
Banned
Default Re: DYNO Numbers(or lack there of)
Originally Posted by Bob G
MBtuner: Great info. on the dyno numbers. 9 hp to the wheels with the power chip and 13 ft-lbs torque! Great! Just to confirm, the stock 3.2 in our Xfires does't need any internal mods to supercharge to 330+ hp? This is what Kleemans also said. Seems too good to be true but I am becoming a believer. Do you know how they got by the relay/sensor for the dyno? If it is just a disconnect, how did you identify the right one? Thanks
I thought you had to change compression meaning valves and pistons. Is this right ?
And lower end bearings.
