Re: Fuel Filter location?
Passenger side in front of rear wheel.
REMOVAL
1. Raise and support the vehicle.
2. Remove the fuel pump splash shield.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT
FUEL PRESSURE EVEN WITH THE ENGINE
OFF. BEFORE DISCONNECTING ANY FUEL LINES,
THIS PRESSURE MUST BE RELEASED.
3. Release the fuel system pressure. (Refer to 14 -
FUEL SYSTEM/FUEL DELIVERY - STANDARD
PROCEDURE).
Note: Place a shop towel around fuel lines to
catch any excess fuel during disassembly.
4. Remove the fuel filter/pressure regulator fuel line
(1).
5. Remove the fuel rail supply line (3) at the fuel filter/
pressure regulator.
6. Remove the fuel delivery hose.
7. Remove the fuel return hose at the fuel filter/pressure regulator.
8. Remove the clamp retaining screw and remove the fuel filter/pressure regulator
INSTALLATION
1. Position the fuel filter/pressure regulator into the
clamp, install the retaining screw and tighten.
2. Install the following hoses/lines in order:
1. The fuel return hose.
2. The fuel delivery hose.
3. The fuel rail supply line (3).
4. The fuel filter/pressure regulator fuel line (1).
3. Tighten the hoses/lines to the fuel filter/pressure
regulator.
4. Install the fuel pump splash shield.
5. Lower the vehicle.
