Old May 28, 2009 | 03:18 PM
SNAKEWOLF's Avatar
SNAKEWOLF
Default Re: Another lightbulb change issue
THE BOLTS ARE ON OUTER CORNERS I HAVE REMOVED MINE
NEED TO BE CAREFUL WHEN YOU REMOVE PUT A CLOTH BETWEEN LIGHT AND BODY ON THE BOTTOM SIDE.
IF NEEDED PUT ON JACK STANDS AND REMOVE OR TURN TIRES SO YOU GET A GOOD VIEW INTO OPENING.
GOOD LUCK
OTIS
