Old May 28, 2009 | 08:35 PM
James1549
Default Re: Wiring for Angel Eyes
There is an easy way to do this without going into the cabin. Use a standard 5 pin relay (we refer to them as a bosch relay). Connect your angel eyes to a fused battery source, and run them through the "normal closed" contacts (30 and 87a) of the relay. Splice the coil circuit (85) to your headlight wiring, (86) to ground. I can draw a diagram if you don't understand.
That way when you turn on your headlights, the relay will engage, turning off your angel eyes. You are using the relay to turn off an item rather than turn on an item. You can get them in ranges from 20a to 50amp. Not sure what the angel eyes draw.
James
