Old May 28, 2009 | 11:14 PM
ACRucrazy's Avatar
ACRucrazy
Default Re: Coil Overs on an SRT!
A fellow member here has had them for over a year, srt6_crossfire.
I hope he doesnt mind me posting his replies to me when I asked for his feedback on them.
Originally Posted by srt6_crossfire
I would only recommend getting it if you're doing road races or autox AND can adjust yourself. If you are not mechanically inclined, it is a PITA to adjust as you'll need to remove the spring to adjust height unlike true coilovers where u just use the wrench that it comes with. This is not a true coilover (ie. coils/spring not over the struts/shocks).
if i can remember correctly, they did roll my fenders. i cant remember if they grinded a bolt which at one point was done, but not sure if it for KW or if it was when i got wheel hubs.
as far as tire rubbing you'll get them. my main complaint with them is that i have it set to medium (height) and i bottom out easy on the freeway when going over some inclined/decline spot when going over at least 80mph.
not an issue with road racing though.
